WCS (wireless controll system) old alarms
jcartes
I'm trying to see the old alarms from WCS, I mean on top of the screen displayed Alarms summary specifically critical alarms (red triangle) when these alarms are resolved which is the record that there ever was this alarm
can any one help my thanx
Federico Ziliotto
You may be able to find back cleared alarms through an advanced search, by choosing Alarms as a Search Category and maybe other parameters such as Clear as a Severity.
Hope this helps,
Fede
If  this helps you and/or answers your question please mark the question as  "answered" and/or rate it, so other users can easily find it.
Federico Ziliotto
Hope this helps,
Fede
thanx for the answer
Thank you, glad this helped.
Feel free to ping us back in the future for any further help on your wireless setup.
Fede
