WCS Wireless Guest Access : Area, building restrictions don't work
elblanco_fr
I use WCS to create guest accounts on a WLC4400 local database. Guest login works fine but i can login with any guest account on any campus, building, floor even if the account is apply only on one of those.
i use a custome Web auth page, this is the cisco's exemple page with our logo.
WLC44000 - 4.2.61.0
WCS - 4.262.11
WLAN Guest setup :
Layer 3 security : none
Web policy : authentication
Over-ride global - config enable
sschmidt
So when you create the guest user you choose the specific campus/building/floor but the users are able to get access anywhere? How many controllers do you have?
Yes exacly.
Only one controller with 15 "campus" (business unit).
AP are in HREAP (for corporate WLAN). of course (i know it's stupid) guest wlan is in a lwapp tunnel and wrong username or password don't works !
