web authentication on WLC 2504
Gaurav Singh
Hi All,
I do know that captive portal could be setup on cisco WLC 2504, such that internet users could login as follows:
Username, password or  mobile number.
And get the authorization code on mobile number.
However I would like to know whether the above configuration would work with just 2504 or do we need any other device to achieve this.
5 Replies 5
Sandeep Choudhary
Hi Garuav,
Webauth will work with 2504 as well. WLC .
WLC can store max 2048 local entries so it depends on your requirement size.
you will need a RADIUS SERVER(We are using ISE) to store/assign guest credentials and send the Code/password via smtp/SMS gateway.
Dont forget to rate helpful posts
Hi Sandeep,
Thanks for your reply,
could you please share configuration guide for RADIUS SERVER(We are using ISE) to store/assign guest credentials and send the Code/password via smtp/SMS gateway.
Gaurav singh
Not openly.....
Check your PM.
I am having problem in Cisco WLC 2504 at https://1.1.1.1
Would you please help to solve this issue ?
If there's any detailed best practiced document available to configure Cisco WLC 2504 with full controlled policies.
Would highly appreciate.
Faisal Raza.
kindly follow below steps:-
Web Auth > Web Login Page
and configure redirect page to http or any http url.
Gaurav
