Wep works - WPA doesn't
jing_nghik
Im desperate for any configuration on my WLC besides wep. Inputting ascii or hex into each phone is a pain and I would love the WPA encryption. What can I do to get this working on the CP-7920. It seems to not want to authenticate. It works fine on WEP with 40, 128 bit, but I just rather have WPA with a preshared key and something easier to remember and less prone to being compromised by the less secure wep encryption.
2 Accepted Solutions
migilles
7920 supports both ascii and hex for WPA-PSK. Can use the config utility via usb to configure the phone if not wanting to use the keypad.
For 802.1x, the 7920 supports only LEAP or EAP-FAST. Set to AKM if using WPA or other key management type.
7920 doesn't support AES. So only WPA-PSK version 1 is supported, but must set mode to AKM and configure the pre-shared key.
The 7921 does support WPA2/AES.
migilles
I didnt know AES had to be set on the actual phones. It worked. Thanks alot !
