08-21-2018 03:03 PM - edited 07-05-2021 09:00 AM
After upgrading a WLC 5508 from code 8.0.133.0 to 8.2.166.0 the WGB changed their behavior.
About every 30 minutes the WGB disassociate and seconds later they associate to the same or another parent.
The WGB consist of different modells - for example AIR-SAP2602I-E-K9 (12.4).
The parents are 2702 APs.
below are the related logging messages
Aug 21 17:02:08.290: %DOT11-4-UPLINK_ESTABLISHED: Interface Dot11Radio0, Associated To AP QML014 70df.2f0c.2222 [None WPAv2 PSK]
Aug 21 17:32:18.080: %DOT11-4-UPLINK_DOWN: Interface Dot11Radio0, parent lost: Received disassociate (1) failure
Aug 21 17:32:19.176: %DOT11-4-UPLINK_ESTABLISHED: Interface Dot11Radio0, Associated To AP QML014 70df.2f0c.2222 [None WPAv2 PSK]
Aug 21 18:02:28.984: %DOT11-4-UPLINK_DOWN: Interface Dot11Radio0, parent lost: Received disassociate (1) failure
Aug 21 18:02:29.996: %DOT11-4-UPLINK_ESTABLISHED: Interface Dot11Radio0, Associated To AP QML013 70df.2f0c.1111 [None WPAv2 PSK]
Aug 21 18:32:39.674: %DOT11-4-UPLINK_DOWN: Interface Dot11Radio0, parent lost: Received disassociate (1) failure
Aug 21 18:32:40.842: %DOT11-4-UPLINK_ESTABLISHED: Interface Dot11Radio0, Associated To AP QML013 70df.2f0c.1111 [None WPAv2 PSK]
Aug 21 19:02:50.576: %DOT11-4-UPLINK_DOWN: Interface Dot11Radio0, parent lost: Received disassociate (1) failure
Aug 21 19:02:51.656: %DOT11-4-UPLINK_ESTABLISHED: Interface Dot11Radio0, Associated To AP QML013 70df.2f0c.1111 [None WPAv2 PSK]
Aug 21 19:33:01.475: %DOT11-4-UPLINK_DOWN: Interface Dot11Radio0, parent lost: Received disassociate (1) failure
Aug 21 19:33:02.539: %DOT11-4-UPLINK_ESTABLISHED: Interface Dot11Radio0, Associated To AP QML010 70df.2f82.1111 [None WPAv2 PSK]
Sometimes the WGB does not associate again and has to be restarted.
The WGBs are stationary.
Any ideas on how to resolve this issue ?
Can anyone help me with that ?
08-21-2018 04:39 PM
Have a look below post, you can try one of the below options
1. Increase the aging-out timer
2. Add static entry in WGB for the passive client
https://mrncciew.com/2013/06/16/ios-ap-wgb-with-multiple-vlan/
Rasika
*** Pls rate all useful responses ***
08-22-2018 09:15 AM
Hi Rasika,
thank you for your reply.
unfortunately both options does not work, the issue is still the same.
But i took a look to the WLC-log, and this entry occures many times:
*apfMsConnTask_2: Aug 22 17:29:36.780: %APF-3-WGB_ADD_WIRED_CLIENT_FAILURE: apf_ms.c:2213 Unable to add wired client 00:22:65:0d:22:22.WGB 64:00:f1:e1:22:22. WGB is not in RUN state.
from there i cam to this bug:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvd23185
and
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvh79627
i think that is it.
I'm gonna try o resolve the issue using this image: AIR-CT5500-K9-8-3-143-0.aes
What do you think ?
sincerely
Klaus
08-22-2018 01:06 PM
As it introduced after a code upgrade, it is more likely code issue.
So give it a try with 8.3.143.0 & see. If all your AP model supported in 8.5.135.0, then you can try that code as well. (8.5.x will be a long live release)
Rasika
11-12-2019 03:05 PM
Did you make any progress with this?
02-18-2021 11:10 AM
Hello Klaus
Did you resolve this issue?
I Have a similar situation,. on my case we are using WGB model IR829, WLC 3504 ( ver 8.5.140.0) and FlexConnect AP model 3802E
WBG are using only 5Ghz with WPA2/PSK Auth.
Every aprox 10-15min WBG receive an death and auth constantly
*Apr 4 04:37:29.300: %DOT11-4-UPLINK_ESTABLISHED: Interface Dot11Radio1, Associated To AP 7061.7bf5.b1ee [None WPAv2 PSK]
*Apr 4 04:43:19.004: %DOT11-4-UPLINK_DOWN: Interface Dot11Radio1, parent lost: Received deauthenticate (7) not authenticated
*Apr 4 04:43:21.544: %DOT11-4-UPLINK_ESTABLISHED: Interface Dot11Radio1, Associated To AP 7061.7bf5.b1ee [None WPAv2 PSK]
*Apr 4 04:53:21.692: %DOT11-4-UPLINK_DOWN: Interface Dot11Radio1, parent lost: Received deauthenticate (7) not authenticated
*Apr 4 04:53:24.192: %DOT11-4-UPLINK_ESTABLISHED: Interface Dot11Radio1, Associated To AP 7061.7bf5.b1ee [None WPAv2 PSK]
*Apr 4 05:14:29.668: %DOT11-4-UPLINK_DOWN: Interface Dot11Radio1, parent lost: Received deauthenticate (7) not authenticated
