What is better way to configure HA for C9800
interfacedy
Folks,
WLC 9800 is going to be installed at ESXi. In physical C9800, we can use two C9800 to do HA, how about virtual one? thanks
ammahend
To form HA you need same platform (both physical or both virtual) and same firmware.
-hope this helps-
Anjana A
Please find the doc with all the cisco recommedation.
https://www.cisco.com/c/dam/en/us/td/docs/wireless/controller/9800/17-1/deployment-guide/c9800-ha-sso-deployment-guide-rel-17-1.pdf
if you found it useful..  provide a star.
Anjana
Refer this document as it describe 9800-HA in virtual 9800
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213915-configure-catalyst-9800-wireless-control.html
Rasika
*** Pls rate all useful responses ***
