11-15-2012 10:58 PM - edited 07-03-2021 11:03 PM
Hello everybody!
I'm having a little issue with some Cisco Aironet1242ag WAP's. I receive a call at least twice a month stating that some of the WAP's are not giving out internet connection. What I always do is go to my patch panel and disconnect those WAP's not working and connect them back again so they can power cycle. These WAP's are connected to a Cisco3750g. Once the WAP's boot up, the users can connect to the WAP and connect to the internet.
I don't know if these WAP's are filling up with some information that causes the access points to not connect to the WAN.
I appreaciate any feedback from you all.
Chuy
11-15-2012 11:18 PM
I assume this AP work as Autonomous AP. Post here config of AP and 3750g. So we can help you.
Your topology looks like this:
AP --> 3750g --> Router --> Internet ?
Abzal
11-15-2012 11:40 PM
Correct, that is the way we have it setup. AP-->3750G-->6509-->Internet.
We also have a DHCP server with VLAN 50 for wireless. On the AP I have it to VLAN 50, on the 3750g I have the port as Switchport mode trunk. On the 6509 the vlan has the iphelper pointing to the DHCP server.
Im sorry that I don't have the configs with me right now, but I should be able to post them tomorrow.
Chuy
11-16-2012 12:35 AM
If I understood you right, users connect to AP and correctly get their IP address on VLAN 50. But do not have access to the Internet. What about local LAN, do they have access to internal resources?
And it happens with all users that connecting to that AP? Or just some of them?
What version of IOS on AP and 3750G?
Abzal
11-19-2012 04:55 PM
Sembay;
Sorry for the delay on answering. I went and got the configs off the switch and an WAP that I need to power cycle so it can work again.
Again, users can connect to internet and local servers fine. The issue is that once in a while I need to turn off and on the WAP when the users cannot connect to this WAP. Once I power off and power it back on the users can connect back again to internet with no problem.
Switch config:
JOH-2950-ANNEX1>
JOH-2950-ANNEX1>ENA
Password:
Password:
Password:
JOH-2950-ANNEX1#
JOH-2950-ANNEX1#
JOH-2950-ANNEX1#show r ver
Cisco IOS Software, C3750 Software (C3750-IPSERVICES-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 19:15 by nachen
Image text-base: 0x00003000, data-base: 0x01280000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SEE4, RELEASE SOFTWARE (fc1)
JOH-2950-ANNEX1 uptime is 32 weeks, 4 days, 3 hours, 41 minutes
System image file is "flash:c3750-ipservices-mz.122-35.SE5/c3750-ipservices-mz.122-35.SE5.bin"
cisco WS-C3750G-48PS (PowerPC405) processor (revision H0) with 118784K/12280K bytes of memory.
Processor board ID FOC1404W285
Last reset from power-on
1 Virtual Ethernet interface
52 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
--More-- 512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address :####.####.####.####
Motherboard assembly number : 73-10216-09
Power supply part number : 341-0108-04
Motherboard serial number : FOC14043B4X
Power supply serial number : DCA1351A69R
Model revision number : H0
Motherboard revision number : C0
Model number : WS-C3750G-48PS-E
System serial number : FOC1404W285
Top Assembly Part Number : 800-27481-02
Top Assembly Revision Number : D0
Version ID : V06
CLEI Code Number : COM7V10ARA
Hardware Board Revision Number : 0x09
Switch Ports Model SW Version SW Image
* 1 52 WS-C3750G-48PS 12.2(35)SE5 C3750-IPSERVICES-M
Configuration register is 0xF
--More--
JOH-2950-ANNEX1#
JOH-2950-ANNEX1#
JOH-2950-ANNEX1#show run
Building configuration...
Current configuration : 4058 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname JOH-2950-ANNEX1
enable secret ********
no aaa new-model
switch 1 provision ws-c3750g-48ps
system mtu routing 1500
ip subnet-zero
no file verify auto
spanning-tree mode pvst
--More-- spanning-tree extend system-id
vlan internal allocation policy ascending
interface GigabitEthernet1/0/1
switchport access vlan 30
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
--More-- interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
--More-- !
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
--More-- switchport access vlan 30
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
--More-- interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
--More-- !
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
description Wireless AP
switchport mode trunk
--More-- !
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
interface GigabitEthernet1/0/49
--More-- switchport mode trunk
interface GigabitEthernet1/0/50
interface GigabitEthernet1/0/51
interface GigabitEthernet1/0/52
interface Vlan1
ip address 10.155.##.# 255.255.255.128
ip default-gateway 10.155.##.#
ip classless
ip http server
control-plane
line con 0
line vty 0 4
password ******
--More-- login
line vty 5 15
login
end
JOH-2950-ANNEX1#
JOH-2950-ANNEX1#
JOH-2950-ANNEX1#wr
[OK]
JOH-2950-ANNEX1#
Wirless Access Point config:
*Jun 16 13:10:56.603: %DOT11-6-ROAMED: Station ####.####.###5 Roamed to ####.####.###0
*Jun 16 13:10:56.603: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station ####.####.###5
*Jun 16 13:10:56.610: %DOT11-4-MAXRETRIES: Packet to client ####.####.###5 reached max retries, removing the client
AnnexAP27#SHOW VER
Cisco IOS Software, C1240 Software (C1240-K9W7-M), Version 12.4(21a)JA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 16-Sep-09 19:06 by prod_rel_team
ROM: Bootstrap program is C1240 boot loader
BOOTLDR: C1240 Boot Loader (C1240-BOOT-M) Version 12.4(13d)JA, RELEASE SOFTWARE (fc2)
AnnexAP27 uptime is 1 week, 4 days, 1 minute
System image file is "flash:/c1240-k9w7-mx.124-21a.JA1/c1240-k9w7-mx.124-21a.JA1"
--More-- to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
cisco AIR-AP1242AG-A-K9 (PowerPCElvis) processor (revision A0) with 24566K/8192K bytes of memory.
Processor board ID FTX1436B256
PowerPCElvis CPU at 262Mhz, revision number 0x0950
1 FastEthernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: ####.####.####.####
Part Number : 73-9925-07
PCA Assembly Number : 800-26579-06
PCA Revision Number : A0
PCB Serial Number : FOC14354QYS
Top Assembly Part Number : 800-29232-02
--More-- Top Assembly Serial Number : FTX1436B256
Top Revision Number : A0
Product/Model Number : AIR-AP1242AG-A-K9
AnnexAP27#
AnnexAP27#SHOW RUN
Current configuration : 1939 bytes
version 12.4
no service pad
service password-encryption
hostname AnnexAP27
enable secret *****
no aaa new-model
dot11 syslog
dot11 ssid Hinojosa
vlan 50
authentication open
guest-mode
--More-- !
username ***** password *****
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid Hinojosa
channel 2432
station-role root
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.50
--More-- encapsulation dot1Q 50
no ip route-cache
bridge-group 160
bridge-group 160 subscriber-loop-control
bridge-group 160 block-unknown-source
no bridge-group 160 source-learning
no bridge-group 160 unicast-flooding
bridge-group 160 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
dfs band 3 block
channel dfs
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
--More-- interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface FastEthernet0.50
ip address 10.155.##.## 255.255.255.128
no ip route-cache
bridge-group 160
interface BVI1
ip address dhcp client-id FastEthernet0
no ip route-cache
ip default-gateway 10.155.##.1
ip http server
--More-- no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
password *****
login
end
AnnexAP27#
AnnexAP27#SHOW
AnnexAP27#
AnnexAP23>
AnnexAP23>
AnnexAP23>
Chuy
11-20-2012 02:54 PM
Hello everyone!
Does anyone have had any issue like this one? Or any recommendations?
Thanks!
Chuy
11-21-2012 04:56 AM
Wrong forum, post in "wireless". You can move your post using the actions panel on the right.
03-07-2013 09:53 PM
I moved the post in the wireless section and was able to get an answer. I found out that the AP's that were deauthenticating had a memory leak. They adviced me to input the following command in the dot11radio interface:
packet retries 128 drop-packet
Thanks a lot!
J.esus.C.
