09-17-2018 02:23 AM - edited 07-05-2021 09:11 AM
I was proposed following diagram for connection of wifi guest anhor:
Firewall-1: to restrict traffic between LAN and DMZ
Firewall-2: provider's device
Is it correct design when anchor is connecting by G1 interface towards firewall-1 and by G-2 interface - towards firewall-2? If it is correct would be good to have some related information.
09-17-2018 02:56 AM - edited 09-17-2018 02:58 AM
Pls refer below for wireless Geust anchoring. You require another controller in your LAN.
Also typically you connect WLCs to a switch. In your DMZ, you should have a switch where you define SVIs (unless that firewall is dedicated to wireless traffic termination)
Rasika
*** Pls rate all useful responses ***
09-17-2018 04:50 AM
yep,
I am not at that elementary level.
Local WLCs are on LAN.
VLAN is expected to be terminated on firewall-2.
The question: is it possible to use anchor as per diagram, one interface connected to firewall-1 and another is to firewall-2.
If I had a layer-3 switch I would not ask this question.
