Wifi Latency
MuhammadSaad_2
Dear All:
Scenario is we have three buildings out of three 2 buildings contain autonomous Access Point and One building contain WLC.
the management and user ssid vlan is same in all the buildings. But when end user connect with User SSID and pings its own gateway is show latency.
Kindly help me in this is very urgent.
Thank You
40 Replies 40
Are you using super sensitive apps?
I have over 6,000 clients / 3,000 aps and work in a hospital with hundreds of applications. Most of which are used over wifi devices like CoW and handhelds. We expereince betwen 5 - 80 ms and arent having any issues.
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
Lets be clear latency and bits per seconds are two different things. And 300 PHY rate doesnt mean 300 megs of throughput, rather it means you are sending 300 million bits per transmission.
In "Local" mode .... windows reports 3 hours and 45 min for the same copy. Still connected at 300Mbit/s
is that right ? Yea somethin is wrong for sure. Is your interface on the swicth and wlc configured properly ?
Agree, but this is a one Client one AP one Controller one Server setup
ok, so the 2504 has a backplane issue, You don't get full Gig speed out of it, you only get about half.
If you are running 7.3 you can utilize LAG on the 2504 to get Gig throughput
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
I am not even close to half gig :-)
I agree you should still see more than you are seeing now.
Just double check your interfaces so we can rule that out. You dont see any errors on the switch and the interafces are clean and not bouncing .
Steve, good to know. Is this documented ? Im running out of bathroom reading material
It's the exact same setup. Only change is "Local" and "flexconnect". Ping from a wired client to controller and ap is always under 1 ms
If i remember correctly (from the bathroom reading) 1 gig should be possible with 7.4.
No real reason to enable LAG :-)
But a hint to MuhammadSaad ... try flexconnect.
I will probably try to reset to factory default tomorrow.
Strange.
Reset to factory default, created one WLAN
No delay.
Loaded old config ----  45 ms delay
What is wrong with the config ?
config location expiry tags 5
config advanced probe limit 2 500
config advanced 802.11a channel add 36
config advanced 802.11a channel add 40
config advanced 802.11a channel add 44
config advanced 802.11a channel add 48
config advanced 802.11a channel add 52
config advanced 802.11a channel add 56
config advanced 802.11a channel add 60
config advanced 802.11a channel add 64
config advanced 802.11a channel add 100
config advanced 802.11a channel add 104
config advanced 802.11a channel add 108
config advanced 802.11a channel add 112
config advanced 802.11a channel add 116
config advanced 802.11a channel add 120
config advanced 802.11a channel add 124
config advanced 802.11a channel add 128
config advanced 802.11a channel add 132
config advanced 802.11a channel add 136
config advanced 802.11a channel add 140
config advanced 802.11a channel dca chan-width-11n 40
config advanced probe-limit 2 500
config advanced 802.11b channel add 1
config advanced 802.11b channel add 2
config advanced 802.11b channel add 3
config advanced 802.11b channel add 4
config advanced 802.11b channel add 5
config advanced 802.11b channel add 6
config advanced 802.11b channel add 7
config advanced 802.11b channel add 8
config advanced 802.11b channel add 9
config advanced 802.11b channel add 10
config advanced 802.11b channel add 11
config advanced 802.11b channel add 12
config advanced 802.11b channel add 13
config auth-list ap-policy authorize-ap enable
config auth-list add mic ec:c8:82:ba:38:e0
config auth-list add mic 00:3a:9a:ab:a1:37
config auth-list add mic 00:19:2f:7e:54:b2
config local-auth method fast server-key encrypt 1 416fad50367c2b32ed72b74bb9b1411d de72c13a971262cdc5c8c40263a80bc3132c6949 16 a538482bf5ddb0fad7c65c4f5163c44800000000000000000000000000000000
config time ntp server 1 192.38.7.240
config time ntp server 2 96.226.123.117
config time ntp server 3 50.77.217.185
config time timezone location 14
config license agent max-sessions 9
config license boot base
config interface address management 192.168.111.22 255.255.255.0 192.168.111.1
config interface address virtual 1.1.1.1
config interface port management 1
config interface nat-address management set 188.177.226.93
config interface nat-address management enable
config interface dhcp management primary 192.168.111.10
config 802.11b cac voice sip codec g711 sample-interval 20
config 802.11b cac voice sip bandwidth 64 sample-interval 20
config 802.11b cleanair alarm device enable 802.11-nonstd
config 802.11b cleanair alarm device enable jammer
config 802.11b cleanair alarm device enable 802.11-inv
config 802.11b cleanair enable
config 802.11b 11gsupport enable
config 802.11b beamforming global enable
config 802.11b rate disabled 1
config 802.11b rate disabled 2
config 802.11b rate disabled 5.5
config 802.11b rate disabled 6
config 802.11b rate disabled 9
config database size 2048
config country DK
config switchconfig strong-pwd consecutive-check disable
config switchconfig strong-pwd case-check disable
config mobility group domain Xiting
config wps client-exclusion ip-theft disable
config network mgmt-via-wireless enable
config network telnet enable
config network rf-network-name Xiting
config network multicast l2mcast disable service-port
config network multicast l2mcast disable virtual
config 802.11a cac voice sip codec g711 sample-interval 20
config 802.11a cac voice sip bandwidth 64 sample-interval 20
config 802.11a cleanair alarm device enable 802.11-inv
config 802.11a cleanair alarm device enable 802.11-nonstd
config 802.11a cleanair alarm device enable jammer
config 802.11a cleanair enable
config 802.11a beamforming global enable
config radius callstationidtype ipaddr
config remote-lan exclusionlist 2 60
config remote-lan create 2 OeApLan OeApLan
config remote-lan interface 2 management
config remote-lan session-timeout 2 0
config remote-lan enable 2
config nmsp notification interval rssi rfid 2
config wlan security wpa akm psk set-key hex encrypt 1 06b3f7a026e87f718a0c18f2720b1620 c50556a71ff25d0aa197bdb30583f11af6953f1f 48 6805fc689969ec27b66da329525955b15ab2e4dbc324e7259bb5f7b72b1f0e3d3c3c28261a94b4ecb586d4c6a4906336000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 1
config wlan security wpa akm psk enable 1
config wlan security wpa akm 802.1x disable 1
config wlan security wpa enable 1
config wlan security web-auth server-precedence 1 local radius ldap
config wlan session-timeout 1 1800
config wlan apgroup add OeApGroup
config wlan apgroup interface-mapping add OeApGroup 1 management
config wlan apgroup interface-mapping add OeApGroup 2 management
config wlan mfp client enable 1
config wlan interface 1 management
config wlan create 1 W111 W111
config wlan band-select allow enable 1
config wlan wmm allow 1
config wlan exclusionlist 1 60
config wlan broadcast-ssid enable 1
config wlan enable 1
config sessions timeout 0
config sysname WLC2504
config certificate generate webauth
config mgmtuser add encrypt admin 1 aa22846567018b19b9a78f25d32b2892 05354c0eaa64c2ac9a02b5c6f201c9005a1b4f8e 16 fb6ab91061954d4b79be5d8413fb46bc0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 read-write
config mgmtuser add encrypt Lobby 1 ae7a156161c1a9538eb39213c7879abc eaba3345251af0f6a95860eaee72ef58aa5ed7a9 16 d066146b6ae4409e86a64194a4c16af40000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 lobby-admin
config rfid timeout 1200
config rfid status enable
config rfid mobility pango disable
transfer download path /
transfer download filename config
transfer download serverip 192.168.111.57
transfer upload datatype config
transfer upload path /
transfer upload filename config
transfer upload serverip 192.168.111.57
Hmmmm ... You're using a 1242?
What antennas are you using?  And how many antennas are installed?
Scott Fella
Disable 40mhz... Also LAG on the 2504 is on the 7.4 not the 7.3. Don't restore the configuration... Build it from scratch. I had an issue with 40mhz and the Intel 62xx with driver version 14. Version 15.x fixed the issue.
-Scott
