WiFi remote office connection
I need to connect 2 remote offices about 50 yards disance.
I would like to ask if there is cisco AP solution so that I could bridge a group of VLAN trunks
on a WiFi conection, I would like to bring a certain number of VLAN trunks to the remote office
using WiFi Connection.
Is it possible in some way ?
thank you
Rick
Stephen Rodriguez
Yes this is possible. For that short of a distance you could use the 1262 running IOS to get this done.
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
johncaston_2
As Stephen mentioned, yes you can.
Get a couple of autonomous IOS 1262 AP's with external antenna
Set one up as the root bridge (the one connected to the main LAN) and set up the remote end as a bridge.
The connectivity to the LAN is by way of trunk ports so you can send multiple VLAN's across the wireless bridge
Good luck
Keep in mind, the 1260 TX @ 200mW and Cisco will only offically support up to 6 dBI max on anetnnas. Just an FYI
