WIFI & RFID tags
Mohamed Sayed
Hi all,
I need to make an integration of the WiFi-Tags & RFID Tags with the Cisco PRIME & Cisco MSE and generate their reports.
also what is the RFID tags and WIFI tags ?
I appreciate your support.
Saurav Lodh
Level 7
Level 7
http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Mobility/WiFiLBS-DG/wifich6.html
http://www.cisco.com/en/US/docs/wireless/controller/7.4/configuration/guides/system_management/config_system_management_chapter_010011.html
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/1-2/user/guide/prime_infra_ug/maint_wireless_optools.html#wp1153875
dear Salodh,
I appreciate your support but I need more illustrate for the benifits of RFID and what can I obtain from it ??
thank you
