Windows laptop not able to join 802.1x SSID on C9800-CL
Simon Z
I am in the middle of migrating WLC 5520 (8.10.190.0) to C9800-CL (17.12.05) while APs remain the same (3802i). AAA servers are ISE 3.4 patch 2. We use centralized switching (no Flex mode). I have an 802.1X SSID allowing both EAP-TLS and PEAP+MSCHAPv2. The SSID on WLC 5520 works for pretty much all devices we have. The same SSID on C9800-CL works for most devices I tested so far but one particular Windows laptop.
  1. The same laptop connects to the SSID on 5520 without any issues using EAP-TLS. Tried different Windows builds (10 and 11) and updated Wi-Fi NIC driver to the latest. Machine certificate is fine. Tried manually adding network with EAP-TLS, and PEAP + MSCHAPv2. None worked with the new C9800-CL.
  2. There is no logs for this particular laptop/MAC on ISE meaning the Authenticator (C9800-CL) is not sending Radius request to Authentication Server (ISE) when the Supplicant client tries to join the SSID.
  3. I did some packet captures on the C9800-CL by providing “Inner Filter MAC” and did a comparison between a successful connection and a failed one.
It’s interesting to notice the captured packets are between the C9800-CL and the AP, but 802.1X authentication is between the supplicant (laptop) and the AP (BSSID MAC). On a successful connection, after the supplicant sends Response with Identity (host/xxxxxx), the AP sends a EAP-TLS Request, and after quite a few EAP packets exchange authentication succeeds.
On a failed connection, after the supplicant sends Response with Identity (host/xxxxxx), the AP just sends a Failure EAP packet and never sends a 802.1X proposal:
This explains why ISE never sees a Radius request for this particular laptop. I’ve tested 5 Windows laptops and a few iOS/Android devices so far, and found only one problematic laptop, but I don’t know how many more out of about 1000 laptops may experience the same issue.
A TAC ticket is going nowhere, and the engineer insists something is wrong with the laptop but doesn’t know what exactly is wrong. I’ve seen some similar issues online and it seems nobody was able to explain why there is no logs on Radius servers. Has anyone seen this?
48 Replies 48
I see same issue month ago' but what can I say' engineer leave us with many Q and dont reply to our comment.
Anyway' what I understand'
There are two inner and outer authc
The identity wlc receive for outer authc is wrong and this make authc failed.
MHM
My understanding is PEAP + MSCHAPv2, PEAP + EAP-TLS etc. use outer and inner authc, but EAP-TLS alone uses only one layer. I am thinking a compatibility issue between 3802 AP and C9800-CL but according to this matrix they are supported.
Yes correct eap-tls use only one authc
Let take it as reference
Connect laptop to wlc 5500 and capture traffic and connect it to wlc 9800 and capture traffic
Then identity response open both packet and share it here let me check different
MHM
Unfortunately the only way to do packet capture on 5520 is to use an AP as monitor AP, which I don't have one handy now. When I try "config ap packet-dump" it says my AP doesn't support it.
Hey @Simon Z, although the 5520 doesn't support packet capture natively you can still achieve it via this flow: https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/211342-packet-captures-on-aireos-wlc.html
Since its Identity response you are after, give this a shot and compare against 9800, for AP side packet capture I would suggest to do an EPC on the switch where AP is connected and do the same for 5520 vs 9800.
Simon Z
It may not be easy to do packet capture on 5520. Wireshark on the laptop seems not be able to capture all 802.11 traffic as the Wi-Fi card doesn't support "Monitor mode". I am going to try if I can do it on the AP.
Mark Elsen
  - @Simon Z    Use client debugging for this  windows laptop using instructions from https://logadvisor.cisco.com/logadvisor/wireless/9800/9800ClientConnectivity
                        These so called RadioActive Traces can be analyzed with Wireless Debug Analyzer
                        Outputs from commands mentioned in https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/217738-monitor-catalyst-9800-kpis-key-performa.html#toc-hId-866973845
                        can also be useful
                        Validate the configuration of your new  C9800-CL controller using the CLI command
                         show tech wireless and feed the output from that  into Wireless Config Analyzer
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Wireless Debug Analyzer shows a simple reason: Cred Fail. For whatever reason, the WLC/AP and the client don't try any of the 802.1X protocols. As soon as the client provides Identity as host/<FQDM>, WLC/AP says Failure.
Wireless Config Analyzer shows 1 error 16 warnings - none seems related to the issue.
In wlc 9800 there is EPC use it to share traffic between WLC abd ISE' let see if WLC is end authc or ISE
Share ISE ver abd wlc ver
MHM
   - @Simon Z    If the issue is experienced on one laptop only and not the rest of them ,then the issue is not related to the wireless infrastructure : my advice is to safe user data , and re-install the laptop from scratch.
  M.
       Beauty and terror
      Just keep going
       No feeling is final
Well, the current Windows 11 was a fresh install. Prior to that I installed Win 10 on it. The reason why I keep digging is this particular laptop has no issue to join the same SSID on 5520. Even though I am not able to capture any EAP packets on 5520, but I have logs on ISE showing it hit the right authC and authA policies using EAP-TLS.
Simon Z
I specify 9800 as source and ISE as destination in EPC, then try to join the SSID on the problematic laptop. Nothing is captured. When I try on a good laptop, I see lots of Radius traffic.
9800 is v17.12.05. ISE is v3.4 patch 2.
Good, now what is good laptop and bad laptop?
What is OS for both laptop?
Simon Z
The bad one is now  Win11 version 24H2 (a fresh install). Tried Win10 on it earlier. Same issue.
The good ones include Win10 (22H2), Win 11 (22H2 and 24H2).
They all have the latest Windows updates.
