wIPS and Cisco 1552e
renoufi
Beginner
Beginner
Hi Experts,
Is the Cisco 1552e in LWAPP mode supposed to support wIPS?  The option is greyed out on my 2504 WLC
Version 7.4.100.60
AIR-CAP1552E-N-K9
7 Replies 7
Surendra BG
Issue the below command..
config ap mode flexconnect submode
Surendra BG
Thanks, but no cigar.
Result pretty much as expected. I've raised (yet another!!) wireless TAC case.
(Cisco Controller) >config ap mode flexconnect submode ?
none           No submode active for the Cisco AP.
pppoe-only     WIPS submode for the Cisco AP.
pppoe-wips     WIPS submode for the Cisco AP.
(Cisco Controller) >config ap mode flexconnect submode wips ?
     Enter the name of the Cisco AP.
(Cisco Controller) >config ap mode flexconnect submode wips SB-AP-01
Unable to set submode. This AP model does not support WIPS submode.
renoufi
Beginner
Beginner
What a crock!
Here's the reply from Cisco.
Where's that number for Avaya?
The 1552E does not support WIPS. I have checked the behavior in the lab as well and also internal documents.
Unfortunately, there is no external document stating the same explicitly.
Priyanka
I hav reached out to the BU to check if this is in the roadmap.. We really appreciate ur patience... i guess we serve our customer better than any other company anyday..
Regarda
Surendra
Surendra BG
n yeah.. thanks for the rating much appreciated..
Surendra
Surendra BG
brilevin
wIPS sub-mode is not supported on the 1530 or 1550 series access points.
A link to documentation can be found here:  http://www.cisco.com/c/en/us/td/docs/wireless/technology/mesh/7-6/design/guide/mesh76/mesh76_chapter_01.html#ID543
Recognize Your Peers
