Wireless AIR LAP 1250G
phemite
My i tried to join this AP to an exisiting wireless network (Controller 3750) but it would just work  and when i consoled to it directly, below was what i discovered, the device loading stop at LWAPP change state to down and the system starts again, and same all over again as below.
Any assistance please.
%LWAPP-5-CHANGED: LWAPP changed state to DOWN
IOS Bootloader - Starting system.
Xmodem file system is available.
11 Replies 11
Scott Fella
You need to attach the whole boot up output from the console. You have any other AP's on this WLC? What code are you running?
-Scott
Hello Scott, please find below.
Yes, there are other same AP's on this WLC, only that this one is new purchase and i want to add it to the wireless network.
flashfs[0]: 11 files, 3 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31868928
flashfs[0]: Bytes used: 6666752
flashfs[0]: Bytes available: 25202176
flashfs[0]: flashfs fsck took 16 seconds.
Reading cookie from flash parameter block...done.
Base Ethernet MAC address: 40:55:39:dd:0d:ae
Loading "flash:/c1250-k9w8-mx.124-10b.JDA1/c1250-k9w8-mx.124-10b.JDA1"...##############################################################################################################################################
File "flash:/c1250-k9w8-mx.124-10b.JDA1/c1250-k9w8-mx.124-10b.JDA1" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1250 Software (C1250-K9W8-M), Version 12.4(10b)JDA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 20-Nov-08 17:44 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01000000
Initializing flashfs...
flashfs[1]: 11 files, 3 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 31868928
flashfs[1]: Bytes used: 6666752
flashfs[1]: Bytes available: 25202176
flashfs[1]: flashfs fsck took 4 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
Warning:  the compile-time code checksum does not appear to be present.
Radio 1 A600 8000 0 0 A8030000 30
Radio 0 0 0 0 0 0 13
tx_paks 1421
tx_paks 100
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1252G-E-K9    (PowerPC 8349) processor (revision C0) with 49142K/16384K bytes of memory.
Processor board ID FCZ1530P003
PowerPC 8349 CPU at 533Mhz, revision number 0x0031
Last reset from power-on
LWAPP image version 4.2.176.0
1 Gigabit Ethernet interface
1 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 40:55:39:DD:0D:AE
Part Number                          : 73-10425-06
PCA Assembly Number                  : 800-27630-06
PCA Revision Number                  : B0
PCB Serial Number                    : FOC152154RU
Top Assembly Part Number             : 800-29533-03
Top Assembly Serial Number           : FCZ1530P003
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1252G-E-K9
The name for the keys will be: AP4055.39dd.0dae.cisco.com
% The key modulus size is 1024 bits
% Generating 1024 bit RSA keys, keys will be non-exportable...[OK]
o
% Invalid input detected at '^' marker.
Press RETURN to get started!
*Mar  1 00:00:06.191: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:06.975: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:08.927: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:02:54.011: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:02:54.031: %SYS-5-RESTART: System restarted --
*Mar  1 00:02:54.031: %SNMP-5-COLDSTART: SNMP agent on host AP4055.39dd.0dae is undergoing a cold start
*Mar  1 00:02:55.063: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:02:55.751: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:02:57.439: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:03:12.443: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Mar  1 00:03:12.447: bsnInitRcbSlot: slot 1 has NO radio
*Mar  1 00:03:12.455: bsnUnlockDevice: not bring radio up: radio 1 is in admin disable state
*Mar  1 00:03:12.599: Logging LWAPP message to 255.255.255.255.
%LWAPP-3-CLIENTERRORLOG: ../lwapp/lwapp_l2.c:152 - discarding msg type 12 in state 5
%CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
%SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 started - CLI initiated
%LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
%DHCP-6-ADDRESS_ASSIGN: Interface GigabitEthernet0 assigned DHCP address 172.21.0.110, mask 255.255.0.0, hostname AP4055.39dd.0dae
Translating "CISCO-LWAPP-CONTROLLER.poocng.local"...domain server (192.168.20.1)
%LWAPP-3-CLIENTEVENTLOG: Controller address 172.21.0.85 obtained through DHCP
%LWAPP-3-CLIENTEVENTLOG: Did not get log server settings from DHCP.
%LWAPP-3-CLIENTEVENTLOG: Performing DNS resolution for CISCO-LWAPP-CONTROLLER.poocng.local
%LWAPP-3-CLIENTERRORLOG: DNS Name Lookup: could not resolve CISCO-LWAPP-CONTROLLER.poocng.local
%LWAPP-5-CHANGED: LWAPP changed state to JOIN
%LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
%LWAPP-5-CHANGED: LWAPP changed state to CFG
%LWAPP-3-CLIENTERRORLOG: Config Request Timer: did not recieve config response (controller - PAN_WLC)
%SYS-4-PUPDATECLOCK: Periodic Clock update with ROMMON failed, because size left in ROMMON (4294967295), size needed (29), error code (-1)
%SYS-5-RELOAD: Reload requested by LWAPP CLIENT. Reload Reason: DID NOT GET CONFIG RESPONSE.
executing...
           cisco Systems, Inc.
tx_paks 1421
tx_paks 100
export@cisco.com.
1 802.11 Radio(s)
o
*Mar  1 00:00:06.971: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:02:53.999: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:02:54.463: %SYS-5-RESTART: System restarted --
*Mar  1 00:02:54.463: %SNMP-5-COLDSTART: SNMP agent on host AP4055.39dd.0dae is undergoing a cold start
*Mar  1 00:02:55.495: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:02:56.183: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:02:57.911: %LINEPROTO-5-UPDOWN: Line prot
User Access Verification
Password: ocol on Interface Dot11Radio0, changed state to down
% Authentication failed
Password:
*Mar  1 00:03:12.915: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Mar  1 00:03:12.919: bsnInitRcbSlot: slot 1 has NO radio
*Mar  1 00:03:12.927: bsnUnlockDevice: not bring radio up: radio 1 is in admin disable state
*Mar  1 00:03:13.075: Logging LWAPP message to 255.255.255.255.
Password:
AP4055.39dd.0dae con0 is now available
Press RETURN to get started.
Password:
Password:
Password:
Password:
Password:
Password:
AP4055.39dd.0dae>
AP4055.39dd.0dae>
AP4055.39dd.0dae>
AP4055.39dd.0dae>
AP4055.39dd.0dae>
AP4055.39dd.0dae>
%LWAPP-5-CHANGED: LWAPP changed state to CFGen
Password:
AP4055.39dd.0dae#
AP4055.39dd.0dae#
AP4055.39dd.0dae#
AP4055.39dd.0dae#
AP4055.39dd.0dae#
AP4055.39dd.0dae#
Scott Fella
Is the AP local to the WLC? Can you place the AP in the same subnet as the WLC manager interface and see if it joins. Then if it does, you can move it back.
-Scott
The APs are directly connected to the WLC (3750)G POE-24
Below is the version of the WLC
Cisco IOS Software, C3750 Software (C3750-IPBASE-M), Version 12.2(25)FZ
Can you put it on the same vlan as the WLC also.
-Scott
The AP acquires DHCP address from the controller and there is a vlan for the APs. Do you want me to manually assign IP (static) to the AP?
Is the WLC and the AP's on the same vlan?
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Yes,they are
TFTP the recovery image to the AP and see if that helps.  You need to download the image from CCO.
Scott
-Scott
Scott Fella
Okay... You haven't hit the max ap count? I would tftp the recovery image back to the AP to see if that works.
-Scott
Saurav Lodh
Level 7
Level 7
