wireless ap 3502
suthomas1
Level 7
Level 7
What does thin client mode mean for cisco 3502 access pt. what configuration is required for it to act like this.
The AP can be just wired to one of the switches on the same subnet, is that all i need to do.
Let me ask you this question:  Do you have a Wireless LAN Controller?
Nothing on configuration part?
Configuration is done on the wireless LAN controller.
Cisco Wireless LAN Controller Configuration Guide, Release 7.0.116.0
13 Replies 13
George Stefanick
Where did you see "thin client mode" ?
Leo Laohoo
thin client mode
The correct term is called controller-based.  You need a wireless controller to operate the 3502.  There's nothing specific to configure.  Just make sure you plug this to the same network to the controller as an initial setup and you should be fine.
Thanks. I am new to wireless, so please help me.
The AP can be just wired to one of the switches on the same subnet, is that all i need to do. Nothing on configuration part?
Another query, what is meant when we say map ssid with vlans.
Yes, there is a controller involved.
and does the mapping mean, each vlan is mapped to a seperate ssid. some thing of that sort.
thanks.
Go through the configuration guide because it will give you more than enough details.
To whoever gave me a +2:
Wow!  I got (+2) for giving the correct answer.  Makes me want to be careful in the future!
ha ha Not me though!!
Surendra BG
George!!! y did u do this to Leo??
Surendra BG
LOL!
I didnt but that was funny!
Leo Laohoo
He he he ... Surendra.
Rob Huffman
Hey leo,
That was not a +2 answer but worthy of a +5 (done!) which hopefully
makes up for this somewhat my friend
Cheers!
Rob
LOL!
Thanks Smooth Rob and George.
... the hazards of giving the correct answer.
