Wireless AP H-Reap vlan mapping changes.
denz_cruel
Our Wireless AP is AIR-CAP3502E-C-K9 with WLC 5500. The issue is that in H-REAP VLAN Mapping the VLAn ID suddenly changes and if I checl the logs I see no downtime on the AP. Please note that this happen to random AP's and sometimes all the AP's in certain office. Anyone can help me?
2 Accepted Solutions
Sandeep Choudhary
HI Denz,
Which version of ios u r running on WLCs?
please check these:https://supportforums.cisco.com/thread/2058870
https://supportforums.cisco.com/thread/2164452
Dont forget to rate helpful posts.
HI Denz,
You are hitting this bug:
https://tools.cisco.com/bugsearch/bug/CSCue75078
Upgrade to 7.3 or 7.4 version, be arware that your AP supports this version.
Please make sure all ur wlans hv the same index number on all the wlcs.. If possible.. This mostly happens when the ap joins the other wlc n that may HV the Alan index number not matching the other wlc..
Reagrds
Sandeep Choudhary
HI Denz,
Software Version: 7.0.116.0
base on the bug report (https://tools.cisco.com/bugsearch/bug/CSCsw6899) the fixed knwo release include
7.0(116.0) but currently we are using it. Anyway this mean that we still need to upgrade to higher version.
HI Denz,
Reagrds
