02-19-2003 09:28 AM - edited 07-04-2021 08:31 AM
I have two aironets about a mile apart that randomly lose their association and then re-associate. Other bridges connecting to the root bridge do not have this problem. This issue started when I upgraded the firmware last year - it went away once the firmware was upgraded to the current version - and has now started again. Any ideas ?
02-20-2003 07:33 PM
a) Make sure you are running latest 12.01 firmware
b) Go to Radio hardware page , try increasing beacon period to 4000 instead default 100 .
c) This bridges works in unlicence band so we need to
verify that there is no interference in that area .
Run link test and switch over to less busy channel
d) Check antenna alignment , RF connector again .
Coax cable between bridge and antenna should be as short as possible.
e)If possible run the bridge in default config ( without
encryption ) and see if you get same problem
f) hardcode the speed to 1 meg and see if links remains steady
03-11-2003 07:04 PM
where can I find information about the beacon period and the impact of increasing and decreasing the value.
Dan
