Wireless Bridging between buildings
jorge.s
we are having another building being acquired by our company, which is located less then a Km away from our current offices. With an visible eye contact between both lines, I was considering implementing Wifi connection between them. But what's the product I will be using, and what's the maximum bandwith I can achieve? I was more looking for something aroung a 1gb uplink...
Jorge
ericgarnel
Level 7
Level 7
A wifi bridge would be easy to do, but if you are looking for 1Gb+ speed, check out an unlicensed microwave solution such as
http://www.commconnect.com/microwave-bridges.shtml
