10-15-2024 06:41 AM
Cisco Catalyst 9800-CL Wireless Controller
17.9.3
I randomly, but constantly, have clients that connect to a wireless network associated with a specific VLAN, but for some reason, get an IP address assignment from a different VLAN. This has occurred with clients that connect to the same wireless network and clients that might hop on different wireless networks. It seems to me that the controller might be caching the client's previous connection and re-associating it when the client reconnects or potentially incorrectly identifying the VLAN.
Does anyone have any insight to what might be happening here?
10-15-2024 06:52 AM
- You may start with a checkup of the 9800-CL Wireless Controller's configuration with the CLI command
show tech wireless (not simple 'show tech') and feed the output from that into Wireless Config Analyzer
M.
10-15-2024 07:08 AM
Thank you. I will run the show tech wireless output through the analyzer.
10-15-2024 06:54 AM
For central switching this is an expected behavior. When clients move around and connect to an access point and this access point is connected to a switch that have different vlans from the privious one, the WLC is able to keep the client IP address in order to avoid reconnection. If the client had to get a new IP address, it would required a new DHCP process, authantication and if any NAT session were in place, it would break. For an application like stream, it would be a terrible experience if clients changes the IP everytime it moves.
10-15-2024 07:51 AM
That makes sense to me, I can see the benefits. Is there a period of time that the client IP address is cached and can a specific record be flushed out when needed?
10-15-2024 09:07 AM
As long as the session remains active, as per cisco docs.
"Inter-Subnet Roaming
Multiple-controller deployments support client roaming across access points managed by controllers in the same mobility group on different subnets. This roaming is transparent to the client because the session is sustained and a tunnel between the controllers allows the client to continue using the same DHCP-assigned or client-assigned IP address as long as the session remains active. "
10-16-2024 02:39 PM
Also 17.9.3 is now seriously out of date and also affected by a critical security vulnerability!
Refer to the TAC recommended link (below) for current recommended code versions.
17.12.3 is the currently recommended version.
Many of us have already upgraded to 17.12.4 + SMUs and APSP for a large number of additional fixes.
