12-01-2014 06:31 AM - edited 07-05-2021 02:02 AM
I'm trying to install a wireless connection between 2 buildings.
Tthere is around 500m between the 2 buildings...
I don't know if with Cisco is it possible to do this ? If it is possible, which models of AP's can I use ? Which antennas ?
Thanks for your feedback,
Alexis
12-01-2014 01:36 PM
Do you have direct line-of-sight between the two buildings?
12-02-2014 12:59 AM
Hi, thanks for the answer.
The problem is that I want to install this solution in a customer environment. But Cisco don't sell and support this AP's model anymore...
http://www.cisco.com/c/en/us/products/wireless/aironet-1300-series/index.html
that's why I'm looking for a recent solution... With recent AP's.
Alexis
12-02-2014 05:47 AM
The replacment gear for the 1300 and 1400 is the 1532 and 1572 ..
12-02-2014 09:59 PM
Please refer to the link for Wireless Antenna portfolio-
http://www.cisco.com/c/dam/en/us/products/collateral/wireless/aironet-antennas-accessories/at_a_glance_c45-513837.pdf
12-02-2014 11:55 PM
Thanks for the link, but how can I know if the reach of the antennas is enough for 500m ?
