07-13-2015 09:02 AM - edited 07-05-2021 03:34 AM
Hey folks,
Have an existing WLC 2504 that may have potential issues. Now, I'm now wanting to trouble-shoot those issues, just replace the controller. That said, I have another (unused) 2504 controller. I have made sure software/firmware matches (7.6.130.0). I have downloaded the current config and uploaded it to the new controller.
Can I literally swap the units out and go on, or is there going to be a bit more issues than that?
Paul
Solved! Go to Solution.
07-13-2015 09:11 AM
If the new controller is configured exactly the same, then you can swap them out and that is not an issue. The main thing is to ensure the ip address/hostname is the same just for connectivity sake. This will ensure access points will join the WLC. Make sure the license is also there!!!
-Scott
07-13-2015 09:11 AM
-Scott
07-14-2015 05:45 AM
Scott,
worked without issue. Thanks again...
