Wireless Dynamic VLAN Assignment
rossirj
Community Member
Has anyone sucessfully implemented Dynamic VLAN assigment. I have not been sucessful. I am using at IOS Based 1200 with ACS 3.2. I am using PEAP as the authentication mechanism and I have tried both SSID assignment and VLAN assignment VIA RADIUS and neither will work. With SSID assignment I get caught in an authenticate/deauthenticate loop. With VLAN assignment it seems like the AP is just ignoring the keys and leaves me in the SSID/VLAN that I initially associate with. I have looked at the Wireless Virtual LAN Deployment guide and cannot find anything different than I am already doing.
hadbou
Level 10
Level 10
I don't think dynamic VLAN feature is supported yet, did it work for you??
svaltel
Community Member
Yes, it's working for me... I used Dynamic VLAN features on my network
In fact in this example, the VLAN 100 is used for the RF Traffic, the VLAN 150 is used for a test access and VLAN 200 is used for the management.
The VLAN 200 is only reachable from the Ethernet Link.
See below one config based ont this :
version 12.2
no service pad
service timestamps log datetime msec show-timezone
service password-encryption
hostname AP-01-1200-CEL1
logging buffered informational
logging console informational
aaa new-model
aaa group server radius rad_eap
server 10.0.0.2 auth-port 1645 acct-port 1646
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa authorization ipmobile default group rad_pmip
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
enable secret 5 XXXXXXXXXXXXXXXXXXXXX
username svaltel privilege 15 password 7 XXXXXXXXXXXXXXXXXXXX
clock timezone B 2
ip subnet-zero
no ip domain lookup
bridge irb
interface Dot11Radio0
no ip address
no ip redirects
no ip unreachables
no ip route-cache
encryption vlan 100 mode ciphers tkip wep128
broadcast-key vlan 100 change 3600
encryption vlan 150 mode ciphers tkip wep128
broadcast-key vlan 150 change 3600
ssid RFCLOE
vlan 100
authentication network-eap eap_methods
accounting acct_methods
infrastructure-ssid optional
ssid TEST
vlan 150
speed basic-1.0 basic-2.0 basic-5.5 basic-11.0
rts threshold 2339
channel 2447
fragment-threshold 2338
station-role root
infrastructure-client
interface Dot11Radio0.100
encapsulation dot1Q 100 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.150
encapsulation dot1Q 150
no ip route-cache
bridge-group 150
bridge-group 150 subscriber-loop-control
bridge-group 150 block-unknown-source
no bridge-group 150 source-learning
no bridge-group 150 unicast-flooding
bridge-group 150 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.100
no ip route-cache
bridge-group 1
interface FastEthernet0.150
encapsulation dot1Q 150 native
no ip route-cache
bridge-group 150
interface FastEthernet0.200
encapsulation dot1Q 200
ip address 10.0.0.100 255.0.0.0
no ip route-cache
bridge-group 200
no bridge-group 200 source-learning
bridge-group 200 spanning-disabled
interface BVI1
no ip address
no ip route-cache
ip default-gateway 10.0.0.1
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag/ivory/1100
ip radius source-interface FastEthernet0.200
snmp-server community RFCLOE RO
snmp-server enable traps tty
radius-server local
group VLAN100
vlan 100
user sebastien.valtel nthash 7 XXXXXXXXXXXXXXXXXXXXXX group VLAN100
radius-server host 10.0.0.2 auth-port 1645 acct-port 1646 key 7 XXXXXXXXX
radius-server retransmit 3
radius-server attribute 32 include-in-access-req format %h
radius-server authorization permit missing Service-Type
radius-server vsa send accounting
radius-server vsa send authentication
bridge 1 route ip
banner motd ^CXXXXXXXXXXXXXXXXX^C
line con 0
line vty 5 15
session-timeout 60
end
svaltel
Community Member
ouppsss.... sorry ... a little mistake :
replace theses lines =
By =
WOW..I have been trying to get VLANs to work for the past three days. Thank you. I am glad I found this forum. I will try the config you mentioned and let you know how it worked. But I need to know how did you release the IP and config from the interface BVI1 and make it no ip address no ip route-cache. Here is my example using IOS 12.2 on a AP1200
ssid Guest
vlan 10
authentication open
ssid LAB
vlan 11
authentication open
rts threshold 2312
station-role root
encapsulation dot1Q 10 native
no ip route-cache
bridge-group 1
interface Dot11Radio0.11
encapsulation dot1Q 11
no ip route-cache
bridge-group 11
bridge-group 11 subscriber-loop-control
bridge-group 11 block-unknown-source
no bridge-group 11 source-learning
no bridge-group 11 unicast-flooding
bridge-group 11 spanning-disabled
no ip address
no ip route-cache
duplex auto
speed auto
ntp broadcast client
no ip route-cache
bridge-group 1
interface FastEthernet0.11
no ip route-cache
bridge-group 11
interface BVI1
ip address 192.168.0.200 255.255.255.0
no ip route-cache
ip default-gateway 192.168.0.1
ip http server
ip radius source-interface BVI1
radius-server host 192.168.0.92 auth-port 1645 acct-port 1646 key xxxxx
bridge 1 route ip
line con 0
line vty 5 15
ntp clock-period 2861628
ntp server 192.168.0.92
end
