返信
Wireless ethernet bridging between 2 different WLC
p3tter123
Hi, i have 2 WLC 1 old and one new version.
I want to create a ethernet bridge between these 2 systems. is that possible?
My old WLC is a 2112 and the new one is a vWLC 8.2.130.
The reason is that i have a small site with a lot of 1131 AP (these APs is not supported in the new vWLC), and i dont want to change them out yet.
So:
Router--->SWITCH-->NEW vWLC--->3602AP------Wireless Bridge------1131AP<-----Old 2112 WLC----SWITCH
1件の返信1
Scott Fella
What do you mean bridge them?  Why do you need to?  Can't you keep sites that are old on the 2112 and use the vWLC when you migrate a site?
-Scott
-Scott
