wireless guest access
Hakan_Aktas
hi,
I want to guest see a web page when they click the internet.
In this web page guest enter his name and his friend's mail adres who are working in our company.
When guest click submit, an e-mail is sent to his friend to accept guest to our guest wireless network.
In this e-mail, visitors name, and his friend name and a link it can be clicked by employee to allow guest.
If our employee accept guest , guest can go internet.
All of these things should be done automatically.
how can i make this thing?
thanks
Scott Fella
WebAuth in the WLC will not do that. You would need to redirect the WebAuth page to an external server in which your web team would create a sash page that can perform that task.
-Scott
Ravi Singh
Level 7
Level 7
You can achieve this task by redirecting the guest to a different webpage which is created by you or your web team. For redirecting to external server please complete these steps:
  1. Log into the GUI of the WLC.
  2. Click on the WLANs tab, and access the profile of             the WLAN configured for Web-authentication.
  3. On the WLAN > Edit page, click the Security tab. Then, choose Layer 3.
  4. On this page, choose None as the Layer 3             Security.
  5. Check the Web Policy box, and choose the             Authentication option.
  6. Check the Over-ride Global Config Enable box,             choose Customized (Downloaded) as the Web Auth Type, and             select the desired login page from the Login Pagepull down             menu. Click Apply.
