wireless login with multiple ssid
saleff
We have a secure ssid and a guest ssid. Is the a way to prompt for a single username and password and if that name is guest it will automatically connect to the guest ssid? If active directory user and password it will automatically use the secure ssid? we are using Microsoft NPS/Radius, 3502 ap's, and 5508 controller.
Stephen Rodriguez
if you are returning IEEE 64/65/81 you can do it, if you have a single SSID.
You wouldn't want your corporate on an unsecured SSID. But the you have to be doing an EAP on the guest as well.
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Stephen Rodriguez
Steve
HTH,
Steve
Hi Stephen,
I searched for info on dynamic Vlan's/IEEE 64/65/81. This is exactly what I want to do. Thanks for pointing me in the right direction.
Michael Burk
You can also use AD to push out a policy to all of your wireless domain devices to automatically connect to the secure ssid using the users windows username and password.
