Wireless Mesh 1552 AP
Neville Price
I am trying to pass a WCS AP Template to my Test Mesh Root AP, when I try and apply the template, I get the following error:
Failure: MEDIATION-1,Attempt to set conflicting attribute value,LradIf,adminStatus,LradIf! followed by the mac address.
This is the first attempt to try and set a mesh Root AP up, any help would be appreciated.
thanks
nev
5 Replies 5
Erwin Salazar
Neville,
What settings are you trying to push via Template on the 802.11b/g/n parameters?
Cheers, Erwin ______________________________________ How helpful was I? Don't forget to rate me when you have the chance!
This is the template I have passed to the RAP
Saravanan Lakshmanan
Is the RAP up?
Are the RAP radios up?
How the RAP is powered?
Wireless>> All APs>> Select RAP>> click advanced - Under "power over ethernet settings" what option is selected. select the power injector if not already and try pushing the template.
The RAP is up, the error occurs when I try and enable the radios. The RAP is poered over ethernet directly from a 3750x with dual power.  Any help would be welcome.
thanks
nev
The radios will not come up when powered up by a PoE switch.  You need to use the power injector specifically for the MESH AP or hard wired to a power source.
http://www.cisco.com/en/US/docs/wireless/access_point/1550/power/guide/1550pwrinj.html
Powering up the 1550:
http://www.cisco.com/en/US/docs/wireless/access_point/1550/installation/guide/1550_ch2.html#wp1068843
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
