If those are 5000 APs then offcourse you need different subnets. But if it is 500 then I don't think you required different - different subnet. Seamless roaming is main goal on the wifi if client will move from one ap to another ap.
Deepak kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
