Wireless question regarding strength
lpettit11
I have two access points one using 802.11N and the other 802.11AC 1st wave. The N has excellent signal strength while the AC is weak and sometimes will not even appear in the same area N appears in.
I was wondering some good troubleshooting methods to try to figure out why N is so much better. I checked and neither have anything that can cause interference.
George Stefanick
Few things:
What channels are both aps on when you observed this
What is the power setting on the aps
What device did you use to test this
