wisim controller and 5760 for vlan design and mobility groups
in our one project they are two wisim 1 module in 6500
and one  5760 controller  connected two same lan network
and 5760 controller is connected two lan network switch 4948 switch
for wisim 1 modules native vlan is compulsary or
we can make controller mgmt ip add for AP registration
And for AP groups for Vlan design there are 28th floor the details of AP as shown below
Floor No. Qty AP Type
Roof Floor 4 cisco 2602 with External Antenna
28th Floor 7  Cisco 1040 with integrated Antenna
27th Floor 7  Cisco 1040 with integrated Antenna
26th Floor 7 cisco 2602 with External Antenna
25th Floor 7  Cisco 1040 with integrated Antenna
24th Floor 7  Cisco 1040 with integrated Antenna
23rd Floor 7  Cisco 1040 with integrated Antenna
22nd Floor 7  Cisco 1040 with integrated Antenna
21st Floor 7  Cisco 1040 with integrated Antenna
20th Floor 7  Cisco 1040 with integrated Antenna
19th Floor 7  Cisco 1040 with integrated Antenna
18th Floor 7  Cisco 1040 with integrated Antenna
17th Floor 7  Cisco 1040 with integrated Antenna
16th Floor 7  Cisco 1040 with integrated Antenna
15th Floor 7  Cisco 1040 with integrated Antenna
14th Floor 7  Cisco 1040 with integrated Antenna
13th Floor 7  Cisco 1040 with integrated Antenna
12th Floor 7  Cisco 1040 with integrated Antenna
11th Floor 7  Cisco 1040 with integrated Antenna
10th Floor 7  Cisco 1040 with integrated Antenna
4th Floor 10  Cisco 1040 with integrated Antenna
3rd Floor 19  Cisco 1040 with integrated Antenna
2nd Floor 18 cisco 2602 with External Antenna
First Floor 17 cisco 2602 with External Antenna
Mezzanine Floor 4 cisco 2602 with External Antenna
Ground Floor 17 cisco 2602 with External Antenna
B1 31 cisco 2602 with External Antenna
B2 11  Cisco 1040 with integrated Antenna
B3 9  Cisco 1040 with integrated Antenna
Total 308
for each Five floor one one AP groups subnet like  192.168.15.x/24
or
for each floor seperate subnets for AP groups Experts please advice
For mobility groups
for two wisim 1 module and 5760 controller
As far i known we cannot make mobility groups for wisim 1 and 5760 controller
expert please advice for mobility groups in this topology
2 Accepted Solutions
in our one project they are two wisim 1 module in 6500 and one  5760 controller  connected two same lan network
WiSM-1 only support upto 7.0.x software code. Hence you cannot register 2600 AP onto it. Refer table 2 of below URL
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
For each Five floor one one AP groups subnet like  192.168.15.x/24 or for each floor seperate subnets for AP groups Experts please advice.
I would put all of these APs in single AP management vlan (/23) rather break it down to floors
As far i known we cannot make mobility groups for wisim 1 and 5760 controller. expert please advice for mobility groups in this topology
Yes, you cannot have this in same mobility group. I would really consider twice before put WiSM-1 into this network. Simply go with 5760 & that make things simple.
Rasika
*** Pls rate all useful responses ***
5 Replies 5
Rasika
Thanks Rasika Nayanajith
Need your advice
1 I will make  two vlan for clients to get ip
1.for wisim controller
2. 5760 controller
2. In my topology mobility will not work Because of wisim 1 module.
3.Regarding Native vlan in 6500 series switch for wisim module there compulsary native vlan for Registering for Acess points
or
with out native vlan if we make mgmt vlan in 6500 series switch  for Registering of Acesspoints
Need ur support for after configuartion for four wireless controller
in core switch 6500 how to configure dhcp server option 43 for these 4 controller for registration APS
and one question
each wism-a will support 150 Acess points
but in our project there 208 Acess points of 1040
