10-06-2008 12:10 AM - edited 07-03-2021 04:34 PM
I have reloaded ( RESET ) the WISM from a 6500 sup 720 . After when the WISM came up I have loosed 80 AP that was previously associated with it.
The logs on the WISM did not say anything important
After 3 days my AP became 5 .
Question : I have to wait a mounth before my WISM will register the others 87 ?
Any suggestion will be appreciated
Alberto
Solved! Go to Solution.
10-07-2008 05:01 AM
What are the access points doing? Are their LEDs changing colors?
The semaphore error is listed at:
http://www.cisco.com/en/US/docs/wireless/controller/message/guide/msgs6.html
Which, unfortunately, provides no help for resolving the issue. It sounds like you'll need to open a TAC case to resolve this.
10-06-2008 05:33 AM
There are actually two controllers built into each WiSM module. Have you checked both controllers to make sure that the access points didn't simply switch over to the other one?
10-06-2008 05:49 AM
Hello
you mean session processor 1 slot 1 ?
We plane an HW-module RESET from 6500 . Do this fix up and reste both controllers ?
10-06-2008 07:56 AM
If you reset the entire module, then both controllers would have been reset. Still, have you checked to see if the access points are on the other controller?
If you can't find them on another controller, go find an access point that's "missing" and see what the LEDs are doing. If they're repeatedly turning red -> amber -> green, then the access points are stuck finding the controller. Try hard-booting one and see if that fixes the problem.
How do access points find the controller? Through broadcast, DHCP, or DNS?
10-06-2008 11:20 PM
I have RESET the entire module and nothing changes . The DHCP is use to comunicate to the AP but the AP are 80 ! Now they are in charge to another AP
regards
10-06-2008 11:37 PM
10-07-2008 05:01 AM
10-07-2008 05:14 AM
Hello
I have already seen this document
And I cannot open a TAC for this issue.
The leds is not possible to seen how they works because is located in very far .
The are registered in other WISM located in different and no more in the WISM where they are before .
So this means that when you reload a WISM it will loose all the AP registered on it ; and another WISM , placed in the same LAN ; will catch the loosed AP
Attached sh tech for references
THANKS
10-08-2008 06:32 AM
That's correct, and you can always use AP fallback mode to get them to go back to their primary WLC one the WLC comes back up.
Glad to see your issue was resolved :D
10-08-2008 06:36 AM
Thanks a lot but previously I was looking at the auto-anchor mobility that is not the same thing
http://www.cisco.com/en/US/docs/wireless/controller/5.0/configuration/guide/c5mobil.html#wp1098994
10-15-2008 02:10 AM
I Don't know if you use an NTP server of local time.
Make sure the WISM is in sinc with the time.(even if it displays the correct time !)
(Press set time once if you do this liocally on the WISM) otherwise make sure connectivity to the NTP server
