WLAN AP 2702i Line protocol goes up and down
Gehrig_W
Hello Cisco WLAN Experts,
we are running 2702i-APs on 9800-WLC SW-Level 17.9.3 which show abnormal behaviour in putting line protcol on
Dot11Radio0- and Dot11Radio2 interfaces state down/up an a regular basis of 15 minutes:
The shown radio reset codes are 27 and 10.
Our Prime 3.10 is reporting "Radio administratively up and operationally down" for these APs.
I can see no channel changes happening.
DCA interval is 10 Minutes . FRA interval is 1 Hour.
What might be the reason for this malbehavour ?
How can I dig deeper into this ?
Please check and thank You for any good hints.
Kind regards
Win
marce1000
                             >.....The shown radio reset codes are 27 and 10.
  - Ref : https://www.cisco.com/c/en/us/support/docs/wireless/aironet-3700-series/117869-technote-ap-00.html
10 RADIO_FC_TX_INPROG The driver attempts to free a packet that the radio still has in progress
27 RADIO_FC_NDP_STUCK --not used--
            - Probably not to meaningful ; if it happens exactly every 15 minutes I suspect an external cause ; examine the wireless traffic at those intervals (e.g.) or                   'just examine the wireless traffic'
  Advised : Have  a checkup of the 9800-WLC configuration with the CLI command show tech wireless ;
feed the output into : https://cway.cisco.com/wireless-config-analyzer/
 M.
Hello Marce1000,
Thank You for Your reply. It looks like You are pointing to an outdated radio reset code table.
I'm using this one
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/tech-notes/ap-radio-reset-codes.html
10  RADIO_RC_IDB_RESET Radio interface reset.
27 RADIO_RC_IDB_SHUTDOWN Radio interface has been shutdown.
Looks like these reflect the correct Reset Codes and Radio Reset Reasons.
Kind regards
Wini
  - Well it depends on how you look at it ; 'my document' says :
                      >....Updated:May 9, 2023
   Yours only has : Updated:December 7, 2020...
  - Anyway probably not too important w.r.t your issue ,
 M.
Gehrig_W
You are right, Your document was recently updated but it references an old SW-release at the beginning:
This article pertains to Cisco IOS® APs running 8.5.135.0 / 15.3(3)JF8 and earlier.
My document is elder but for newer SW-Releases:
In 8.5.140.0 / 15.3(3)JF9 and later, the Radio Reset Codes were changed; see the article Cisco Access Point Radio Reset Code Reference for the current behavior.
Kind regards
Wini
Older and cooler
