Wlan configuration
jmb09
Level 2
Level 2
On cisco aironet 1830 mobility express ther is something i don't understand ....
When i declare a wlan on the vlan&firewall screen i configure "use vlan tagging" it ask me "Native Vlan ID" and "Vlan ID".
I well understanding "Vlan ID" but i don't understand "Native Vlan ID" ....
My Ap is connect to a cisco C2960, on this switch native vlan is vlan 1. So in Wlan declaration should i configure "Natice Vlan ID to 1 or should i declare a "Native Vlan ID"="Vlan ID"
In my case i would configure 2 Wlan one should be connected on vlan 1 and the other should be connected to vlan 2. And i don't undestand wich vlan configure for Native ID. I think i had to put the same native vlan as my switch's native valn but i have a real doubt!
8 Replies 8
native vlan using to transport untagged frames received on trunk interfaces through the trunk network. you can use VLAN 1 as native in both WLANs.
Good luck
KB
ammahend
Agree with Kasun, just to elaborate a little ..
The link between your switch and Mobility express is a trunk, so the native vlan on both side need to match, if the switch side is configured as vlan 1 as native then on ME native vlan should also be 1.
For WLANs your Vlan can be anything I would not recommend 1, use it anything other than 1, use 2 and 3.
if you kept 2 WLANs in vlan 2 and 3, it means WLAN traffic will be tagged in vlan 2 and 3 and all other traffic like management plane traffic, control plane traffic etc will be automatically placed in vlan1, because your native vlan (vlan for untagged traffic) is 1.
-hope this helps-
jmb09
Level 2
Level 2
Hello everybody,
First thanks for your explanation i began to understand !
Wlan1 serve users on VLAN1, so native VLAN is 1.
Wlan2 serve users on VLAN2, so native vlan should be VLAN 1 due to trunk betweek switch and ap.
Wlan3 serve users on VLAN 50, so native vlan should also be 1 for the same reason !
In my configuration i will not arrive to change native vlan on WLAN2 or three and when i arrived it changed on the other Wlan and my wlan didn't runs ...
Thanks...
i'm not yet a pro of cisco's product .... May be one day, so thanks you for your help !
In fact i have 3 Wlan to configure
Rich R
You've configured native vlan 1 on WLAN1 and native vlan 2 on WLAN2 and WLAN3.  You cannot do that - you can only have 1 native VLAN which must match the switchport the AP is connected to so it must be vlan 1.  The native vlan is a function of the trunk port not the WLAN.  As the others have explained the native vlan traffic is untagged (no 802.1q VLAN tagging on the frame).  Behaviour for that configuration will be unpredictable and is definitely unsupported.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
jmb09
Level 2
Level 2
Hello !
That's what i have understood but it 's impossible for me to change native vlan in one Wlan without the native vlan in the other Wlan change automatically ....
By example if i put native vlan in Wlan 2 to 1, native vlan in Wlan1 change to 2 and so on .....
I really don't understand !
Rich R
Ok I think I can see what the problem is...  I've always avoided ME myself so not that familiar with it.
I think for WLAN1 you need to select Use VLAN Tagging NO because you're using vlan 1 which is the native (untagged) VLAN.
Then I think that will allow you to correctly set the native VLAN for the other WLANs to 1.
Try that?
jmb09
Level 2
Level 2
Hello !
Thanks for your answer ...
I just try your solution ! And oj for Wlan 1 i configured it to "user vlan tagging" to no ! But impossible to change native Vlan in the other wlan, modify one modify the other ...
Mobility express version is 8.5.140.0
I have an old backup without the third Wlan, i think i will restore it and create again the last WALN or may be one of my AP have a problem ....
Thanks !
Rich R
Also try updating to 8.5.182.0 or 8.10.171.0 in case this is a known bug that's been fixed in the latest release.
