06-13-2012 04:31 PM - edited 07-03-2021 10:18 PM
Hi friend,
I have a questión its posibble to integrated web autenticaction with external Oracle DB. I want to use user which is located in Oracle DB to enter the network.
Thank for all.
Best Regard,
Marco.
06-13-2012 04:38 PM
Yes. The WLC can be configured to do an LDAP call.
Steve
06-13-2012 05:22 PM
Thank for your answer stephen,
I try to undertand firts i have to integrate the WLC with LDAP and then LDAP integrate with Oracle DB. its correct
Thank.. Marco.
06-13-2012 05:41 PM
If the Oracle DB can respond to the LDAP call you could go there directly. I'm not a DB person do I don't know if it can/will or what configuration it would take.
Steve
06-13-2012 05:45 PM
Ok.. i go to find out about this type of integration.
Thank for all.
06-22-2012 03:52 AM
one more thing to add if you managed to know if the DB is kind of directory based ( that supports LDAP Query ) make sure to have LDAP browser to check all the attributes available and map them on the LDAP server configuration page on your WLC.
