WLAN traffic flow (two different SSIDs)
Kyujin Choi
   Thanks for your knowledge and time.
   I like to know real traffic flow. For example, AIR-AP-1252AG (left top corner) has two SSIDs (Internal and Guest). Internal goes to Core switch (right top corner) and main internet. Guest goes to Core swithc -> 3560 -> WLC -> guest internet.
  When a user is associated with "internal" SSID from AP Air-AP1252AG (left top), does it go to core switch and internet directly? or it must go to Core -> 3560 -> WLC -> and come back 3560 -> Core -> Internet?
Jacob Snyder
Level 5
Level 5
Let's assume that these APs are in local mode.  In that case, all client traffic goes to the WLC > 3560 > 6500 > Internet.
In local mode the WLC is the point where all wireless traffic terminates onto the wired network.
abwahid
Level 4
Level 4
Physically Traffic flow would be the same from Guest and Internal SSID to the internet.
Normaly the flow is  clients > APs > Access Switch(we use becasue of limited ports in WLC) > WLC > Core Switch
Logically and virtualy traffic flow is different and seprated depends on configuration you made.
Abhishek Abhishek
Yes, if the WLC are in local mode then all client traffic goes to the WLC > 3560 > 6500 > Internet.
