03-14-2022 03:09 AM
hello
I have WLC 2500
I connect AIR-CAP1702I-E-K9 to POE port but I can't config AP
03-14-2022 03:19 AM
>...but I can't config AP
- What do you mean by the above phrasing ? If the AP is supposed to join with a controller , then it is configured by the controller. If it can not join then post AP boot sequence and also look at the controller logs when the AP tries to join.
M.
03-14-2022 09:25 AM
the air-cap not show in WLC
and this is log
no log about AP
*sntpReceiveTask: Mar 14 07:22:53.104: %SNTP-3-FATAL_ERROR_OCCURED: sntp_main.c:233 Fatal error: : unable to send NTP packet to ::.
*sntpReceiveTask: Mar 14 07:22:51.104: %SNTP-3-FATAL_ERROR_OCCURED: sntp_main.c:233 Fatal error: : unable to send NTP packet to ::.
*sntpReceiveTask: Mar 14 07:22:49.104: %SNTP-3-FATAL_ERROR_OCCURED: sntp_main.c:233 Fatal error: : unable to send NTP packet to ::.
*sntpReceiveTask: Mar 14 07:22:47.104: %SNTP-3-FATAL_ERROR_OCCURED: sntp_main.c:233 Fatal error: : unable to send NTP packet to ::.
*sntpReceiveTask: Mar 14 07:22:45.104: %SNTP-3-FATAL_ERROR_OCCURED: sntp_main.c:233 Fatal error: : unable to send NTP packet to ::.
03-14-2022 09:46 AM
>...SNTP-3-FATAL_ERROR_OCCURED
- The latter seems to be a bug , https://bst.cloudapps.cisco.com/bugsearch/bug/CSCun88824 , use latest advisory aireos release on controller and or it is important that there is there is a working and operational NTP setup too.
M.
03-14-2022 03:23 AM
create internal DHCP pool in WLC and enable DHCP proxy
03-14-2022 03:43 AM
Also make sure that time on WLC must be up to date.
Dont forget to rate helpful posts
03-14-2022 09:07 AM
I configure DHCP Scope and dhcp Like photo and update the time and date
but not working
03-14-2022 09:26 AM - edited 03-14-2022 09:31 AM
log in ap
*Mar 1 00:17:17.491: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
03-14-2022 10:14 AM
- Make sure AP can acquire an IP address from the DHCP server. Check DHCP server logs to verify
M.
03-14-2022 11:27 PM
are AP and WLC in same subnet? if not then did you configure option 43 under DHCP scope for APs or any other method so that AP can find the WLC!
