03-28-2018 07:07 AM - edited 07-05-2021 08:26 AM
hi every one
i have WLC 2504 and its work normally , i want to create a new WLAN with Separated vlan but i want to work with PPPOE service , i want to put my broadband user and broadcast it with Separate SSID ?
Can i do that and how ?
03-28-2018 05:07 PM
You need to select the AP mode.
Take a look on this guide:
-If I helped you somehow, please, rate it as useful.-
03-31-2018 03:24 AM
hi
i tried to do that but when i changed the AP mode to flex-connect the AP change to (Standalone) mode!
and can't register with the WLC !
there is note to change MTU from AP , i connected the AP with console cable and changed his interface MTU to 1564 and the same problem stayed ( the AP cannot registered with the WLC )
03-31-2018 03:57 AM
and another things
if i enable flex-connect service where i can put my Broadband username and password ?
and can i enable more than VLAN in the same AP
my situation here is :
i have many place need service test every time , every place with a different VLAN , my idea here
i want to create WLAN with B.B , and put username and password of Test-user , and just changed the VLAN id when i want to test another place , is all this clear ? and its possible or not ?
Best regards .
