07-07-2011 07:43 AM - edited 07-03-2021 08:24 PM
I have a WLC 5008 running with 40 AIR-LAP1042N-E-K9 and country code BE (Belgium) configured.
I also have some AIR-AP1142N-C-K9 which I converted to CAPWAP OS.
Unfortunattely only 1 of the 2 radio interfaces is working because of regulatory reasons.
(the AP's are -C models which stands for China - although they were bought in Belgium too).
I tried to activate the country codes for BE and China, but the WLC won't accept both.
Is there a way to get the 2nd radio interface working ?
thanks,
tom
07-08-2011 12:14 AM
1) I can set up my 5508 without a problem to BE + China country codes. Why is yours rejecting it ?
2) The original problem is that you were sold Chinese APs in Belgium. Contact your reseller and tell him to go lower on the coffee :-)
07-25-2011 02:51 AM
Hi Nicolas,
Thx for the answer.
To activate the counry codes for BE and China, I first had to disable all B-g-n networks (meaning all radio interfaces).
Now the 2 country codes are activated, but I can't switch an AP's country code.
(advanced tab -> country code)
I get this error: Error is setting the country code
Any idea ?
07-29-2011 07:48 AM
I solved my problem.
Had to disable all the radio interfaces again on the controller, then change the AP's from country code, then reactivate everything again ...
Very user friendly :-)
