02-14-2014 10:16 AM - edited 07-05-2021 12:12 AM
I have never needed to pull a config from my 5508's till now.
I have been trying out the WLC Config Analyzer app and it inputs the sh run-config output.
I have yet to find the command to turn off the "more" line brake in 7.4.110.0 code. In a 7mb file, it is a lot of space bar strokes!
I tried to use the Controller Transfer commands to tftp the config (comma delimited, very short WLCCA fails) or running-config (visually normal but premature end).
Where does one configure and AP to send its syslog to a specific target?
dlr
Solved! Go to Solution.
02-14-2014 10:39 AM
HI,
Type "config paging disable" in priviledged mode to set your terminal to display without any breaks.
Dont forget to rate helpful posts
02-14-2014 11:07 AM
Hi David,
If you have a TFTP server setup then you can take a config backup of your WLC by issuing following commands on your WLC CLI.
transfer upload datatype config
transfer upload path .
transfer upload filename 20140212-WLC01.txt
transfer upload serverip
transfer upload mode tftp
transfer upload start
y
If you have a FTP server with username/password to access it then you can use FTP method as well
transfer upload mode ftp
transfer upload username
transfer upload password
y
Rasika
**** Pls rate all useful responses ****
02-14-2014 10:39 AM
HI,
02-14-2014 11:07 AM
Hi David,
y
y
Rasika
02-14-2014 02:56 PM
Sandeep, thank you. that made the result much cleaner.
Riska,
I tried the Transfer routines but the resulting config is in a format that is not readable by the WLCCA, and the resulting running-config (in clear text) is ends half way thru as compaired to the console screen dump..
but with paging disabled it is a non-issue.
Thank you
02-14-2014 03:06 PM
Hi David,
Yes WLCCA only accept "show run-config" output. Here is the all information about WLCCA
https://supportforums.cisco.com/docs/DOC-1373
If you want to restore a WLC config then that FTP/TFTP backup will be useful. Here is a reference for that
http://mrncciew.com/2013/01/25/backup-restore-wlc-configs/
By the way thanks for using rating system as well.
Rasika
*** Pls rate all useful resposnes ****
