Tim Harber
Beginner
WLC 5508 - Set SNMP traps differently per AP
Hey All,
We have a controller with multiple remote AP's connected to it.  A couple of the AP's are at branch offices connected to very low quality DSL connections (which is all that is available) and because of this those AP's cut SNMP traps constantly.  For example last month one AP cut about 50 traps because the DSL connection kept cutting out...usually for only a few seconds/minutes.
I looked though and couldnt find a way to set the traps per AP...only globally.  Is there a way to change the threshold per AP so for example it will only cut a trap if the AP is seen down for a 24 hour period as opposed to everytime it only goes down for a few minutes?
Thanks!
0 REPLIES 0
Content for Community-Ad
