WLC 5508 web auth
aamer
I have Cisco WLC 5508, its working with an old web auth certificate (SHA1), and i want to cancel it, and create a web auth without ssh.
how i can cancel the ssl and change the web auth from "HTTPS" to "HTTP"?
best regards
Did you try this:
For earlier than WLC Release 7.2 code, you must disable HTTPS management of the WLC and leave HTTP management. However, this only allows the web management of the WLC over HTTP.
or
upgrade the WLC to 7.2 or higher version to disable HTTPs on webauth.
Dont forget to rate helpful posts
7 Replies 7
Sandeep Choudhary
Download a new SSL cert to WLC  and reboot the controller for the new certificate to take effect.
SecurityWebauth > Certificate
thanks for your answer,
so i can't remove the ssl and work with HTTP?
you can disable HTTPs from GUI as well.
Check the last lines of the post:
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wlan-security/115951-web-auth-wlc-guide-00.html#anc28
the command to disable can't work! (config network web-auth secureweb disable)
"Incorrect usage.  Use the '?' or <TAB> key to list commands."
and when i press TAB to see the command:
"(Cisco Controller) >config network web-auth
port           Configures additional ports for web-auth redirection.
proxy-redirect Configures proxy redirect support for web authentication clients."
which version you are running on WLC ?
Product Version.................................. 7.0.116.0
Did you try this:
or
