ā11-21-2018 08:35 AM - edited ā07-05-2021 09:29 AM
First time posting here sorry for bad english,
I'm trying to configure multiples vlan in a single SSID ( i think it's not possible by not having either a radius server or ACS ), so i'm trying to create local mac filter and set it to an interface and use an interface group in my SSID. But the think is, it's got ranfom IP from the group interface and not the interface that i set interface in the mac filter.
My question is, is it actually possible for this kind of configuration works ?
Thanks a lot
Ari
Solved! Go to Solution.
ā11-22-2018 12:11 AM
Hi Ari,
Great to hear that.
If that is what you were looking for, you can mark it as accepted solution.
Rasika
ā11-21-2018 11:02 AM
when you use interface group,users will get IP in round-robin fashion.
https://mrncciew.com/2013/01/27/understanding-vlan-select-feature/
You can use AP groups, if you want to assign different vlan to same SSID as well. In that case AP group 1 you can map vlan x where as AP group 2 you can map vlan Y & so on...
Rasika
*** Pls rate all useful responses ***
ā11-21-2018 10:18 PM
Thanks Rasika,
I've just trying that and it's seems to works. Thanks a lot.
Ari
Hi Ari,
Great to hear that.
Rasika
