06-22-2016 03:14 AM - edited 07-05-2021 05:16 AM
Hi to all,
We have some SSID, only one of this use the webauth.
If i join the SSID with webauth, and i leave this without authentication, and after i join one of others SSID (without webatuh), all query DNS response with 1.1.1.1 (virtual IP).
Anyone have a workaround?
06-22-2016 04:19 AM
Could you please clarify...what exactly you are having issue ?
Can you access internet after joining to webauth SSID and before moving to other ssid?
Dont forget to rate helpful posts
06-22-2016 05:38 AM
When i change SSID, and move to others, without webauth, seems the webauth follow me...and all query DNS have reply 1.1.1.1 .
Thank you
06-22-2016 05:58 AM
If other ssid are not using webauth then its not possible...
Question:
How you are moving to other SSID while joining to old webauth SSID(without auth), by click on Forget the network or by any other method?
Is Fast SSID change enable on WLC?
dont forget to rate helpful posts
