WLC 7.0 => Limit possible numbber of connected clients per AP
I was wondering if bug CSCsu24197 (Add limit to the number of association per AP) was fixed in a recent WLC release ?
=> https://supportforums.cisco.com/message/3328600#3328600
We are using WLC 7.0.116.0 and we would like to know if it was possible to limit the number of users PER access-point on the WLC with some recent  releases ?
Thank you very much.
Samir
5 Replies 5
Hello Saravanan,
Thank you very much for your quick answer.
I understand it is possible in WLC 7.2 (so not possible possible in 7.0).
Do you know from which exact version this feature is supported ?
Best regards.
Samir
Hello Saravanan,
Thanks again.
In the above link for 7.0.116.0 I can see "Configure the Maximum Number of Clients per WLAN" but not
"Configuring Maximum Number of Clients per AP Radio Per WLAN"
And under my GUI in 7.0.116.0 I cannot see the option.
I suppose the option is supported only from 7.2 ?
Best regards.
Samir
Per AP Radio limit introduced from 7.2. You may have cli only config for Per WLAN limit.
Per WLAN limit introduced from 7.0.116.0.
http://www.cisco.com/en/US/docs/wireless/controller/7.2/command/reference/cli72commands.html#wp13169011
config wlan max-associated-clients max-clients wlanid
