I have just set up 3 x 5508 WLC's. They are all running the 7.2 software. I have 2 corporate WLC's on seperate sites and a guest WLC in a DMZ at head office.
We have 3 SSID's. I corporate SSID which works fine. 1 of the Guset SSID's works fine with web-auth works fine with the lobby ambassador created guest accounts.
The 3rd is a BYOD guest ID which terminates on the guest controller. It works fine in the following manner.
Client Connects => DHCP is recieved from the Guest Anchor WLC. The authentication is setup to be Radius authentication to a Cisco ACS 5.2 server which authenticates to AD. Everything works fine apart from the fact that the Authentication request is sent via the corporate WLC? This is not the desired affect. The Authentication should be via the Guest Anchor. Is there a way to make this happen?
David
