03-13-2015 02:41 AM - edited 07-05-2021 02:42 AM
In web interface on my WLC 7500 v8.0.110, i don't have the Native VLAN ID text box when i configure the flexconnect on LAP.
I test with IE9, FIREFOX and Google Chrome.
I can configure this parameter in CLI but not in GUI.
Any idea ?
For information, i have another WLC (virtual) in version 7.6 and the Native VLAN ID text box is present with the same browser.
03-30-2015 02:26 AM
I have the same problem with WLC 2504 v8.0.110 but only with AP 1702.
Anyone has a solution?
Is a software upgrade needed?
03-30-2015 12:34 PM
You both hitting bug CSCus64073. The workaround for now is to untick vlan support and tick it back. When you do that, the field will be shown again.
03-31-2015 01:38 AM
Thanks for the infotmation but the untick/tick VLAN Support (in the FlexConnect tab) does not work for me, even if I click on apply between the two and after.
04-01-2015 01:37 PM
In that case I would advise you to make the changes on the CLI until the bug has been resolved in the next maintenance release.
(Cisco Controller) >config ap disable <APName>
(Cisco Controller) >config ap flexconnect vlan native <vlanid> <APName>
(Cisco Controller) >config ap enable <APName>
04-02-2015 02:21 AM
OK, thanks for the CLi commands.
Julien
