09-23-2019 07:02 PM - edited 07-05-2021 11:02 AM
We have around 6000 AP3600 Air-cap3602I-A-K9 both AP and WLC are on 8.5.135.0
We have our 8510 sending Traps for:
Link UP/Down
AP Register
AP UP/DOWN
We get many AP interface status DOWN traps that generate incident tickets examples below:
AP interface status DOWN: Heartbeat Timeout
AP interface status DOWN: New Discovery
AP interface status DOWN: Radio Admin State Change
AP interface status DOWN: Deauth client completed.
AP interface status DOWN: Max Re-transmission
I have a few questions
Should I be able to see the above trap messages in SNMP trap logs?
I never see trap messages incidents for AP interface status UP
Is there a way we can automate and check if an AP is REGISTERED to its controller????
Seems like AP's are sensitive to Border gateway Protocol Bounces in our routers at remote offices and generate taps when this happens
How are others receiving and getting AP Down / UP Traps that generate incident tickets......
Thanks for any info on this!
09-24-2019 07:08 AM
09-24-2019 08:30 AM - edited 09-24-2019 08:34 AM
If BGP flaps then you have a network connectivity failure and your APs are going down so you should expect to see traps for that obviously!
Yes you should see up traps but they actually come from a different MIB (yes...) - maybe that's why you're missing them?
Down: SNMPv2-MIB::snmpTrapOID.0 (1.3.6.1.6.3.1.1.4.1.0): 1.3.6.1.4.1.14179.2.6.3.8 (AIRESPACE-WIRELESS-MIB::bsnAPDisassociated)
Up: SNMPv2-MIB::snmpTrapOID.0 (1.3.6.1.6.3.1.1.4.1.0): 1.3.6.1.4.1.9.9.513.0.4 (CISCO-LWAPP-AP-MIB::ciscoLwappApAssociated)
Those are taken from Wireshark packet capture decodes of the traps in case you're wondering.
You could dampen the response to short outages - eg: wait 10 minutes if you receive AP down. If it's still down after 10 minutes then create trouble ticket. If you receive AP up in that time then the fault is cleared and you never open a ticket for it. Depends on whether your monitoring/ticketing is capable of doing that.
Rich
