WLC 9800 AP 9130 LED and Flash settings not stable after Reboot
Gehrig_W
Hello Cisco WLAN experts,
this big hospitals deployed Cisco 9130 WLAN APs also in rooms for patient and call-on-duty rooms for doctors and nurses.
To not disturb the night silence by green or mostly blue LED of WLAN APs, we disabled LED- and Flash-state:
But unfortunately, after a Power-loss or Reboot of the WLAN AP, these settings return to factory default apparently and LED is active again:
Another point I found is that after disabling LED state only, the LED starts disco-mode blinking:
Is this normal procedure or a bug on a 9880-80-WLC running 17.9.3-code ?
Please check
Kind regards
Wini
marce1000
  - FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwf09259 , following the Known Fixed Release info's have a try with
        17.9.4
 M.
8 Replies 8
marce1000
        17.9.4
 M.
Gehrig_W
Hello marce1000, thank You very much for Your information.
as soon as 17.9.4 will be a TAC recommended releasae, I will upgrade to it.
Kind regards
Wini
    - FYI : https://community.cisco.com/t5/wireless/aironet-2800-access-points-and-catalyst-9800-40-with-ios-xe-17-9/m-p/4915512#M260249
 M.
                   >...as soon as 17.9.4 will be a TAC recommended release, I will upgrade to it.
  Being recommended now :  https://software.cisco.com/download/home/286316412/type/282046477/release/Cupertino-17.9.4
 M.
JPavonM
Additionally, the Flash State Enabled feature means that you make the flash to blink always. This is to locate the AP so the behaviour you see is expected, even with the LED status disabled.
Gehrig_W
Hello JPavonM,
but normal expectation of mine would be that after I disable the LED, it is disabled totally.
It makes no sense to me, that the LED changges from solid state into bliniking permantently in that case.
Disabled means disabled for me.
Kasper Roholt
In 17.9.4 CSCwf09259 is not resolved in this setup "9800-80 (HA) /9120 + 2802 running 17.9.4.27"
When reset AP switchport with LED state: disabled it comes up with LED state: enabled
@Kasper Roholt  Then you should raise a TAC  case,
 M.
