WLC 9800 L C | AP IW-6300H not join
noor_amri
Hi guys,
Fresh installation with 2 unit WLC9800 and 4 type of AP below:-
1) AIR-AP3802E-K-K9
2) AIR-AP3802I-K-K9
3) AIR-AP1562E-L-K9
4) IW-6300H-AC-L-K9
WLC controller ver 17.4.01
All type of AP success join to WLC accept IW-6300H-AC-L-K9 model. any special configuration for this AP?
Your advice are really appreciate.
noor_amri
Problem solve
on CLI just change the mode AP. "capwap ap mode local"
marce1000
 - Check if the particular AP is compatible with the controller-platform :
                              Wireless compatibility matrix
 M.
Hi Marce
Thanks for the reply.
Seen mentioned AP in list -> Cisco Catalyst Industrial Wireless 6300 Heavy Duty Series Access Point
- 'Seen' or being mentioned is not enough , you need to lookup for instance, first AireOS or XE controller-software support-release (e.g.)
 M.
noor_amri
Problem solve
