11-06-2020 12:30 AM - edited 07-05-2021 12:45 PM
Good Day,
How can I trunk the interface(s) directly on the WLC CLI?
11-06-2020 01:30 AM
You just need to configure trunk on switch port not on WLC side.
Dont forget to rate helpful posts
11-06-2020 01:36 AM
Thank you - I have done so but then I lose connectivity to the WLC
11-06-2020 01:41 AM
paste the config of swicthport where WLC is connected.
Also paste the output of this command from WLC: show interface detail management
11-06-2020 01:50 AM
Below resolved my issue: configuring the uplink on the switch with below (I did not add the config: switchport trunk native vlan x)
switchport
switchport mode trunk
Thanks again
11-06-2020 05:32 AM
Both side configuration must match else it will not work.
