WLC anchor between different platform and release
Hi to all,
I have two old wlc4402 with release 7.0.235.3 and I have new wlc 3504 (into DMZ for guest access) release 8.5.131.0. Is it possible to do an anchor configuration for wlan guest?
thanks a lot
Roberto
marce1000
 - What do you mean, in this case , by anchor configuration ?
M.
thanks for support,
anchor configuration it's mean configure a wireless lan for guest users.
This is the link that explan the configuration.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-5/Enterprise-Mobility-8-5-Design-Guide/Enterprise_Mobility_8-5_Deployment_Guide/WirelessNetwork_GuestAccessService.pdf
Is it ok?
most likely it will work, you are running most recent (?) version on the 4400?
Wireless Guest Access FAQ
Can I create Ethernet over IP (EoIP) tunnels between controllers that run different software versions?
Not all Wireless LAN Controller software versions support this. In such cases the remote and anchor controller should run the same version of WLC software. However, the recent software versions do allow the remote and anchor controllers to have different versions.
